Time Before: 0.00961 seconds
Time After: 0.01229 seconds
Time Taken: 0.00268 seconds
Time Before: 0.01240 seconds
Time After: 0.01307 seconds
Time Taken: 0.00066 seconds
Time Before: 0.01332 seconds
Time After: 0.01359 seconds
Time Before: 0.01439 seconds
Time After: 0.01683 seconds
Time Taken: 0.00243 seconds
Time Before: 0.01366 seconds
Time After: 0.02185 seconds
Time Taken: 0.00819 seconds
Time Before: 0.02582 seconds
Time After: 0.02624 seconds
Time Before: 0.02920 seconds
Time After: 0.03139 seconds
Time Taken: 0.00219 seconds
Time Before: 0.02495 seconds
Time After: 0.03161 seconds
Time Taken: 0.00666 seconds
Time Before: 0.05243 seconds
Time After: 0.05258 seconds
Time Before: 0.05990 seconds
Time After: 0.06112 seconds
End call of global.php: 0.063186168670654
Time Before: 0.06671 seconds
Time After: 0.06703 seconds
Time Before: 0.06948 seconds
Time After: 0.07096 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=105327'
Time Before: 0.08844 seconds
Time After: 0.08872 seconds
Page generated in 0.087342023849487 seconds with 9 queries, spending 0.0094397068023682 doing MySQL queries and 0.077902317047119 doing PHP things.
