Time Before: 0.01392 seconds
Time After: 0.02054 seconds
Time Taken: 0.00662 seconds
Time Before: 0.02061 seconds
Time After: 0.02093 seconds
Time Before: 0.02114 seconds
Time After: 0.02127 seconds
Time Before: 0.02205 seconds
Time After: 0.02471 seconds
Time Taken: 0.00265 seconds
Time Before: 0.02134 seconds
Time After: 0.02885 seconds
Time Taken: 0.00751 seconds
Time Before: 0.03769 seconds
Time After: 0.03815 seconds
Time Before: 0.04065 seconds
Time After: 0.04182 seconds
Time Taken: 0.00117 seconds
Time Before: 0.03694 seconds
Time After: 0.04205 seconds
Time Taken: 0.00512 seconds
Time Before: 0.06462 seconds
Time After: 0.06476 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"38.91,\";s:9:\"lastcheck\";i:1784816922;}', 1)Time Before: 0.07607 seconds
Time After: 0.07675 seconds
Time Taken: 0.00068 seconds
Memory Before: 3,439.656 KB
Memory After: 3,439.906 KB
Memory Used: 0.250 KB
Time Before: 0.09121 seconds
Time After: 0.09252 seconds
Time Taken: 0.00131 seconds
Memory Before: 3,526.469 KB
Memory After: 3,527.063 KB
Time Before: 0.10213 seconds
Time After: 0.10230 seconds
Memory Before: 4,164.406 KB
Memory After: 4,164.836 KB
Time Before: 0.10495 seconds
Time After: 0.10640 seconds
Memory Before: 4,446.055 KB
Memory After: 4,447.742 KB
UPDATE session SET lastactivity = 1784816922, location = '/forums/private.php?do=newpm&explain=1&u=105351' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.12305 seconds
Time After: 0.12341 seconds
Memory Before: 4,919.781 KB
Memory After: 4,920.008 KB
