Time Before: 0.00152 seconds
Time After: 0.00215 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00226 seconds
Time After: 0.00292 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00321 seconds
Time After: 0.00334 seconds
Time Before: 0.00401 seconds
Time After: 0.00672 seconds
Time Taken: 0.00272 seconds
Time Before: 0.00339 seconds
Time After: 0.01011 seconds
Time Taken: 0.00672 seconds
Time Before: 0.01191 seconds
Time After: 0.01212 seconds
Time Before: 0.01347 seconds
Time After: 0.01466 seconds
Time Before: 0.01134 seconds
Time After: 0.01484 seconds
Time Taken: 0.00350 seconds
Time Before: 0.02001 seconds
Time After: 0.02013 seconds
Time Before: 0.02215 seconds
Time After: 0.02339 seconds
Time Before: 0.02644 seconds
Time After: 0.02663 seconds
Time Before: 0.02868 seconds
Time After: 0.03015 seconds
UPDATE session SET lastactivity = 1784865017, location = '/forums/private.php?do=newpm&explain=1&u=105354', badlocation = 1 WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.04256 seconds
Time After: 0.04283 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
