Time Before: 0.02146 seconds
Time After: 0.02968 seconds
Time Taken: 0.00822 seconds
Time Before: 0.02976 seconds
Time After: 0.03022 seconds
Time Before: 0.03043 seconds
Time After: 0.03054 seconds
Time Before: 0.03125 seconds
Time After: 0.03380 seconds
Time Taken: 0.00255 seconds
Time Before: 0.03061 seconds
Time After: 0.03808 seconds
Time Taken: 0.00747 seconds
Time Before: 0.04880 seconds
Time After: 0.04918 seconds
Time Before: 0.05164 seconds
Time After: 0.05285 seconds
Time Before: 0.04814 seconds
Time After: 0.05307 seconds
Time Taken: 0.00493 seconds
Time Before: 0.09189 seconds
Time After: 0.09204 seconds
Time Before: 0.11187 seconds
Time After: 0.11307 seconds
End call of global.php: 0.11589908599854
Time Before: 0.12471 seconds
Time After: 0.12486 seconds
Time Before: 0.12762 seconds
Time After: 0.12909 seconds
SET lastactivity = 1776606649, location = '/forums/private.php?do=newpm&explain=1&u=105359'
Time Before: 0.14850 seconds
Time After: 0.14875 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.14745807647705 seconds with 9 queries, spending 0.0079395771026611 doing MySQL queries and 0.13951849937439 doing PHP things.
