Time Before: 0.02252 seconds
Time After: 0.02607 seconds
Time Taken: 0.00355 seconds
Time Before: 0.02617 seconds
Time After: 0.02659 seconds
Time Before: 0.02702 seconds
Time After: 0.02713 seconds
Time Before: 0.02794 seconds
Time After: 0.03017 seconds
Time Taken: 0.00223 seconds
Time Before: 0.02719 seconds
Time After: 0.03453 seconds
Time Taken: 0.00734 seconds
Time Before: 0.04116 seconds
Time After: 0.04164 seconds
Time Before: 0.04413 seconds
Time After: 0.04533 seconds
Time Before: 0.04054 seconds
Time After: 0.04559 seconds
Time Taken: 0.00505 seconds
Time Before: 0.07555 seconds
Time After: 0.07568 seconds
Time Before: 0.09259 seconds
Time After: 0.09473 seconds
Time Taken: 0.00214 seconds
Time Before: 0.10369 seconds
Time After: 0.10384 seconds
Time Before: 0.10686 seconds
Time After: 0.10918 seconds
Time Taken: 0.00232 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=105405', badlocation = 1 WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.12509 seconds
Time After: 0.12537 seconds
