Time Before: 0.00710 seconds
Time After: 0.01051 seconds
Time Taken: 0.00341 seconds
Time Before: 0.01060 seconds
Time After: 0.01111 seconds
Time Before: 0.01135 seconds
Time After: 0.01146 seconds
Time Before: 0.01221 seconds
Time After: 0.01443 seconds
Time Taken: 0.00222 seconds
Time Before: 0.01151 seconds
Time After: 0.01878 seconds
Time Taken: 0.00727 seconds
Time Before: 0.02353 seconds
Time After: 0.02388 seconds
Time Before: 0.02662 seconds
Time After: 0.02787 seconds
Time Before: 0.02277 seconds
Time After: 0.02811 seconds
Time Taken: 0.00534 seconds
Time Before: 0.04417 seconds
Time After: 0.04434 seconds
Time Before: 0.05346 seconds
Time After: 0.05472 seconds
End call of global.php: 0.057152986526489
Time Before: 0.06130 seconds
Time After: 0.06144 seconds
Time Before: 0.06428 seconds
Time After: 0.06577 seconds
SET lastactivity = 1782980241, location = '/forums/private.php?do=newpm&explain=1&u=105413', badlocation = 1
Time Before: 0.08548 seconds
Time After: 0.08588 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.084341049194336 seconds with 9 queries, spending 0.0078907012939453 doing MySQL queries and 0.076450347900391 doing PHP things.
