Time Before: 0.00363 seconds
Time After: 0.00497 seconds
Time Taken: 0.00134 seconds
Time Before: 0.00510 seconds
Time After: 0.00562 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00593 seconds
Time After: 0.00607 seconds
Time Before: 0.00702 seconds
Time After: 0.01011 seconds
Time Taken: 0.00308 seconds
Time Before: 0.00616 seconds
Time After: 0.01567 seconds
Time Taken: 0.00951 seconds
Time Before: 0.01873 seconds
Time After: 0.01948 seconds
Time Taken: 0.00075 seconds
Time Before: 0.02255 seconds
Time After: 0.02386 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01787 seconds
Time After: 0.02411 seconds
Time Taken: 0.00625 seconds
Time Before: 0.03169 seconds
Time After: 0.03185 seconds
Time Before: 0.03410 seconds
Time After: 0.03537 seconds
Time Before: 0.03836 seconds
Time After: 0.03851 seconds
Time Before: 0.04072 seconds
Time After: 0.04261 seconds
Time Taken: 0.00189 seconds
UPDATE session SET lastactivity = 1776535088, location = '/forums/private.php?do=newpm&explain=1&u=105414', badlocation = 1 WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.05592 seconds
Time After: 0.05623 seconds
