Time Before: 0.00343 seconds
Time After: 0.00461 seconds
Time Taken: 0.00118 seconds
Time Before: 0.00472 seconds
Time After: 0.00527 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00572 seconds
Time After: 0.00584 seconds
Time Before: 0.00675 seconds
Time After: 0.00907 seconds
Time Taken: 0.00232 seconds
Time Before: 0.00592 seconds
Time After: 0.01431 seconds
Time Taken: 0.00839 seconds
Time Before: 0.01690 seconds
Time After: 0.01734 seconds
Time Before: 0.02032 seconds
Time After: 0.02150 seconds
Time Before: 0.01616 seconds
Time After: 0.02168 seconds
Time Taken: 0.00552 seconds
Time Before: 0.02658 seconds
Time After: 0.02674 seconds
Time Before: 0.02903 seconds
Time After: 0.03030 seconds
Time Before: 0.03439 seconds
Time After: 0.03456 seconds
Time Before: 0.03670 seconds
Time After: 0.03815 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=105429', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05304 seconds
Time After: 0.05330 seconds
