Time Before: 0.00769 seconds
Time After: 0.01039 seconds
Time Taken: 0.00270 seconds
Time Before: 0.01048 seconds
Time After: 0.01093 seconds
Time Before: 0.01117 seconds
Time After: 0.01136 seconds
Time Before: 0.01228 seconds
Time After: 0.01518 seconds
Time Taken: 0.00290 seconds
Time Before: 0.01145 seconds
Time After: 0.01891 seconds
Time Taken: 0.00746 seconds
Time Before: 0.02301 seconds
Time After: 0.02346 seconds
Time Before: 0.02597 seconds
Time After: 0.02731 seconds
Time Taken: 0.00133 seconds
Time Before: 0.02237 seconds
Time After: 0.02750 seconds
Time Taken: 0.00513 seconds
Time Before: 0.04891 seconds
Time After: 0.04913 seconds
Time Before: 0.05680 seconds
Time After: 0.05813 seconds
Time Before: 0.06478 seconds
Time After: 0.06497 seconds
Time Before: 0.06817 seconds
Time After: 0.06966 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=105433', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.08735 seconds
Time After: 0.08775 seconds
