Time Before: 0.00707 seconds
Time After: 0.00880 seconds
Time Taken: 0.00173 seconds
Time Before: 0.00890 seconds
Time After: 0.00929 seconds
Time Before: 0.00956 seconds
Time After: 0.00974 seconds
Time Before: 0.01058 seconds
Time After: 0.01302 seconds
Time Taken: 0.00244 seconds
Time Before: 0.00982 seconds
Time After: 0.01751 seconds
Time Taken: 0.00769 seconds
Time Before: 0.02097 seconds
Time After: 0.02148 seconds
Time Before: 0.02413 seconds
Time After: 0.02531 seconds
Time Taken: 0.00118 seconds
Time Before: 0.02029 seconds
Time After: 0.02555 seconds
Time Taken: 0.00525 seconds
Time Before: 0.04107 seconds
Time After: 0.04121 seconds
Time Before: 0.04810 seconds
Time After: 0.04930 seconds
Time Before: 0.05498 seconds
Time After: 0.05510 seconds
Time Before: 0.05743 seconds
Time After: 0.05888 seconds
UPDATE session SET lastactivity = 1784785680, location = '/forums/private.php?do=newpm&explain=1&u=105460' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.07694 seconds
Time After: 0.07722 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
