Time Before: 0.00604 seconds
Time After: 0.00751 seconds
Time Before: 0.00762 seconds
Time After: 0.00806 seconds
Time Before: 0.00829 seconds
Time After: 0.00841 seconds
Time Before: 0.00926 seconds
Time After: 0.01138 seconds
Time Taken: 0.00212 seconds
Time Before: 0.00848 seconds
Time After: 0.01644 seconds
Time Taken: 0.00795 seconds
Time Before: 0.01972 seconds
Time After: 0.02015 seconds
Time Before: 0.02375 seconds
Time After: 0.02494 seconds
Time Before: 0.01890 seconds
Time After: 0.02520 seconds
Time Taken: 0.00630 seconds
Time Before: 0.03966 seconds
Time After: 0.03982 seconds
Time Before: 0.04572 seconds
Time After: 0.04694 seconds
Time Before: 0.05238 seconds
Time After: 0.05256 seconds
Time Before: 0.05516 seconds
Time After: 0.05666 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=105471' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.07424 seconds
Time After: 0.07453 seconds
