Time Before: 0.00146 seconds
Time After: 0.00194 seconds
Time Before: 0.00202 seconds
Time After: 0.00253 seconds
Time Before: 0.00282 seconds
Time After: 0.00293 seconds
Time Before: 0.00385 seconds
Time After: 0.00617 seconds
Time Taken: 0.00231 seconds
Time Before: 0.00302 seconds
Time After: 0.01065 seconds
Time Taken: 0.00764 seconds
Time Before: 0.01251 seconds
Time After: 0.01289 seconds
Time Before: 0.01458 seconds
Time After: 0.01584 seconds
Time Before: 0.01182 seconds
Time After: 0.01613 seconds
Time Taken: 0.00431 seconds
Time Before: 0.02233 seconds
Time After: 0.02246 seconds
Time Before: 0.02477 seconds
Time After: 0.02603 seconds
Time Before: 0.02898 seconds
Time After: 0.02914 seconds
Time Before: 0.03124 seconds
Time After: 0.03312 seconds
Time Taken: 0.00188 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=105475' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05353 seconds
Time After: 0.05375 seconds
