Time Before: 0.00147 seconds
Time After: 0.00203 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00212 seconds
Time After: 0.00255 seconds
Time Before: 0.00275 seconds
Time After: 0.00288 seconds
Time Before: 0.00357 seconds
Time After: 0.00640 seconds
Time Taken: 0.00283 seconds
Time Before: 0.00293 seconds
Time After: 0.01066 seconds
Time Taken: 0.00773 seconds
Time Before: 0.01305 seconds
Time After: 0.01347 seconds
Time Before: 0.01601 seconds
Time After: 0.01736 seconds
Time Taken: 0.00136 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01227 seconds
Time After: 0.01766 seconds
Time Taken: 0.00538 seconds
Memory After: 2,261.703 KB
Time Before: 0.02291 seconds
Time After: 0.02306 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02495 seconds
Time After: 0.02618 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.02924 seconds
Time After: 0.02939 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03244 seconds
Time After: 0.03386 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=105495' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04926 seconds
Time After: 0.04962 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
