Time Before: 0.00180 seconds
Time After: 0.00239 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00248 seconds
Time After: 0.00284 seconds
Time Before: 0.00305 seconds
Time After: 0.00322 seconds
Time Before: 0.00404 seconds
Time After: 0.00663 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00327 seconds
Time After: 0.01148 seconds
Time Taken: 0.00821 seconds
Time Before: 0.01405 seconds
Time After: 0.01446 seconds
Time Before: 0.01738 seconds
Time After: 0.01863 seconds
Time Before: 0.01322 seconds
Time After: 0.01889 seconds
Time Taken: 0.00567 seconds
Time Before: 0.02619 seconds
Time After: 0.02641 seconds
Time Before: 0.02855 seconds
Time After: 0.02991 seconds
Time Taken: 0.00136 seconds
End call of global.php: 0.031623840332031
Time Before: 0.03286 seconds
Time After: 0.03301 seconds
Time Before: 0.03521 seconds
Time After: 0.03683 seconds
Time Taken: 0.00162 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=105518'
Time Before: 0.04979 seconds
Time After: 0.05003 seconds
Page generated in 0.048843860626221 seconds with 9 queries, spending 0.0083765983581543 doing MySQL queries and 0.040467262268066 doing PHP things.
