Time Before: 0.02575 seconds
Time After: 0.03431 seconds
Time Taken: 0.00856 seconds
Time Before: 0.03443 seconds
Time After: 0.03494 seconds
Time Before: 0.03518 seconds
Time After: 0.03529 seconds
Time Before: 0.03599 seconds
Time After: 0.03864 seconds
Time Taken: 0.00265 seconds
Time Before: 0.03535 seconds
Time After: 0.04245 seconds
Time Taken: 0.00710 seconds
Time Before: 0.05447 seconds
Time After: 0.05483 seconds
Time Before: 0.05750 seconds
Time After: 0.05871 seconds
Time Before: 0.05367 seconds
Time After: 0.05898 seconds
Time Taken: 0.00531 seconds
Time Before: 0.08160 seconds
Time After: 0.08175 seconds
Time Before: 0.09967 seconds
Time After: 0.10158 seconds
Time Taken: 0.00190 seconds
Time Before: 0.11522 seconds
Time After: 0.11561 seconds
Time Before: 0.11851 seconds
Time After: 0.12072 seconds
Time Taken: 0.00222 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=105519', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.13938 seconds
Time After: 0.13974 seconds
