Time Before: 0.00372 seconds
Time After: 0.00516 seconds
Time Before: 0.00523 seconds
Time After: 0.00576 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00602 seconds
Time After: 0.00613 seconds
Time Before: 0.00698 seconds
Time After: 0.00992 seconds
Time Taken: 0.00295 seconds
Time Before: 0.00622 seconds
Time After: 0.01391 seconds
Time Taken: 0.00769 seconds
Time Before: 0.01576 seconds
Time After: 0.01609 seconds
Time Before: 0.01888 seconds
Time After: 0.02006 seconds
Time Before: 0.01519 seconds
Time After: 0.02026 seconds
Time Taken: 0.00506 seconds
Time Before: 0.02573 seconds
Time After: 0.02585 seconds
Time Before: 0.02996 seconds
Time After: 0.03124 seconds
End call of global.php: 0.032866954803467
Time Before: 0.03495 seconds
Time After: 0.03510 seconds
Time Before: 0.03758 seconds
Time After: 0.03925 seconds
Time Taken: 0.00167 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=105528'
Time Before: 0.05655 seconds
Time After: 0.05681 seconds
Page generated in 0.055583000183105 seconds with 9 queries, spending 0.0085823535919189 doing MySQL queries and 0.047000646591187 doing PHP things.
