Time Before: 0.00155 seconds
Time After: 0.00201 seconds
Time Before: 0.00207 seconds
Time After: 0.00333 seconds
Time Before: 0.00390 seconds
Time After: 0.00409 seconds
Time Before: 0.00488 seconds
Time After: 0.00737 seconds
Time Taken: 0.00249 seconds
Time Before: 0.00416 seconds
Time After: 0.01079 seconds
Time Taken: 0.00662 seconds
Time Before: 0.01296 seconds
Time After: 0.01337 seconds
Time Before: 0.01591 seconds
Time After: 0.01709 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01234 seconds
Time After: 0.01727 seconds
Time Taken: 0.00493 seconds
Time Before: 0.02277 seconds
Time After: 0.02298 seconds
Time Before: 0.02474 seconds
Time After: 0.02599 seconds
End call of global.php: 0.027591943740845
Time Before: 0.02876 seconds
Time After: 0.02897 seconds
Time Before: 0.03091 seconds
Time After: 0.03230 seconds
Time Taken: 0.00139 seconds
SET lastactivity = 1780641134, location = '/forums/private.php?do=newpm&explain=1&u=105540', badlocation = 1
Time Before: 0.04455 seconds
Time After: 0.04493 seconds
Page generated in 0.043646097183228 seconds with 9 queries, spending 0.0089521408081055 doing MySQL queries and 0.034693956375122 doing PHP things.
