Time Before: 0.00194 seconds
Time After: 0.00251 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00261 seconds
Time After: 0.00320 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00350 seconds
Time After: 0.00363 seconds
Time Before: 0.00458 seconds
Time After: 0.00727 seconds
Time Taken: 0.00268 seconds
Time Before: 0.00371 seconds
Time After: 0.01207 seconds
Time Taken: 0.00836 seconds
Time Before: 0.01486 seconds
Time After: 0.01533 seconds
Time Before: 0.01692 seconds
Time After: 0.01811 seconds
Time Before: 0.01416 seconds
Time After: 0.01837 seconds
Time Taken: 0.00420 seconds
Time Before: 0.02502 seconds
Time After: 0.02514 seconds
Time Before: 0.02701 seconds
Time After: 0.02849 seconds
End call of global.php: 0.030882120132446
Time Before: 0.03209 seconds
Time After: 0.03227 seconds
Time Before: 0.03439 seconds
Time After: 0.03620 seconds
Time Taken: 0.00180 seconds
SET lastactivity = 1789015930, location = '/forums/private.php?do=newpm&explain=1&u=105552', badlocation = 1
Time Before: 0.04931 seconds
Time After: 0.04957 seconds
Page generated in 0.047979116439819 seconds with 9 queries, spending 0.0089282989501953 doing MySQL queries and 0.039050817489624 doing PHP things.
