Time Before: 0.02097 seconds
Time After: 0.02784 seconds
Time Taken: 0.00687 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.02793 seconds
Time After: 0.02843 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.02872 seconds
Time After: 0.02884 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.02961 seconds
Time After: 0.03242 seconds
Time Taken: 0.00280 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.02889 seconds
Time After: 0.03655 seconds
Time Taken: 0.00766 seconds
Memory Before: 560.883 KB
Memory After: 1,641.883 KB
Memory Used: 1,081.000 KB
Time Before: 0.04202 seconds
Time After: 0.04244 seconds
Memory Before: 2,136.727 KB
Memory After: 2,137.344 KB
Time Before: 0.04503 seconds
Time After: 0.04627 seconds
Memory Before: 2,148.906 KB
Memory After: 2,148.766 KB
Time Before: 0.04129 seconds
Time After: 0.04653 seconds
Time Taken: 0.00523 seconds
Memory Before: 2,128.906 KB
Memory After: 2,261.789 KB
Time Before: 0.08359 seconds
Time After: 0.08380 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.09988 seconds
Time After: 0.10113 seconds
Memory Before: 2,903.656 KB
Memory After: 2,904.250 KB
Time Before: 0.11376 seconds
Time After: 0.11396 seconds
Memory Before: 3,540.422 KB
Memory After: 3,540.852 KB
Time Before: 0.11644 seconds
Time After: 0.11789 seconds
Memory Before: 3,821.953 KB
Memory After: 3,823.641 KB
UPDATE session SET lastactivity = 1785316407, location = '/forums/private.php?do=newpm&explain=1&u=105567' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.13644 seconds
Time After: 0.13680 seconds
Memory Before: 4,295.914 KB
Memory After: 4,296.141 KB
