Time Before: 0.00145 seconds
Time After: 0.00200 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00207 seconds
Time After: 0.00266 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00292 seconds
Time After: 0.00306 seconds
Time Before: 0.00372 seconds
Time After: 0.00628 seconds
Time Taken: 0.00257 seconds
Time Before: 0.00311 seconds
Time After: 0.01010 seconds
Time Taken: 0.00699 seconds
Time Before: 0.01247 seconds
Time After: 0.01286 seconds
Time Before: 0.01440 seconds
Time After: 0.01554 seconds
Time Taken: 0.00114 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01181 seconds
Time After: 0.01572 seconds
Time Taken: 0.00392 seconds
Memory After: 2,261.703 KB
Time Before: 0.02274 seconds
Time After: 0.02291 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02560 seconds
Time After: 0.02692 seconds
Time Taken: 0.00132 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.03114 seconds
Time After: 0.03132 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03433 seconds
Time After: 0.03580 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=105568' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05133 seconds
Time After: 0.05161 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
