Time Before: 0.02376 seconds
Time After: 0.03484 seconds
Time Taken: 0.01108 seconds
Time Before: 0.03495 seconds
Time After: 0.03553 seconds
Time Taken: 0.00057 seconds
Time Before: 0.03575 seconds
Time After: 0.03591 seconds
Time Before: 0.03668 seconds
Time After: 0.03943 seconds
Time Taken: 0.00275 seconds
Time Before: 0.03599 seconds
Time After: 0.04381 seconds
Time Taken: 0.00782 seconds
Time Before: 0.05235 seconds
Time After: 0.05281 seconds
Time Before: 0.05526 seconds
Time After: 0.05644 seconds
Time Taken: 0.00118 seconds
Time Before: 0.05161 seconds
Time After: 0.05667 seconds
Time Taken: 0.00506 seconds
Time Before: 0.10392 seconds
Time After: 0.10411 seconds
Time Before: 0.12925 seconds
Time After: 0.13053 seconds
Time Before: 0.14296 seconds
Time After: 0.14333 seconds
Time Before: 0.14611 seconds
Time After: 0.14759 seconds
UPDATE session SET lastactivity = 1784795949, location = '/forums/private.php?do=newpm&explain=1&u=105601' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.16925 seconds
Time After: 0.16957 seconds
