Time Before: 0.02426 seconds
Time After: 0.03237 seconds
Time Taken: 0.00811 seconds
Time Before: 0.03245 seconds
Time After: 0.03294 seconds
Time Before: 0.03323 seconds
Time After: 0.03342 seconds
Time Before: 0.03424 seconds
Time After: 0.03711 seconds
Time Taken: 0.00287 seconds
Time Before: 0.03349 seconds
Time After: 0.04160 seconds
Time Before: 0.05373 seconds
Time After: 0.05418 seconds
Time Before: 0.05682 seconds
Time After: 0.05844 seconds
Time Taken: 0.00163 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.05294 seconds
Time After: 0.05867 seconds
Time Taken: 0.00573 seconds
Memory After: 2,261.703 KB
Time Before: 0.08705 seconds
Time After: 0.08719 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.10612 seconds
Time After: 0.10737 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.11738 seconds
Time After: 0.11755 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.12010 seconds
Time After: 0.12154 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=105606' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.14055 seconds
Time After: 0.14087 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
