Time Before: 0.01843 seconds
Time After: 0.02555 seconds
Time Taken: 0.00712 seconds
Time Before: 0.02564 seconds
Time After: 0.02606 seconds
Time Before: 0.02628 seconds
Time After: 0.02654 seconds
Time Before: 0.02735 seconds
Time After: 0.02959 seconds
Time Taken: 0.00224 seconds
Time Before: 0.02662 seconds
Time After: 0.03376 seconds
Time Taken: 0.00715 seconds
Time Before: 0.04024 seconds
Time After: 0.04065 seconds
Time Before: 0.04220 seconds
Time After: 0.04343 seconds
Time Before: 0.03943 seconds
Time After: 0.04361 seconds
Time Taken: 0.00418 seconds
Time Before: 0.07670 seconds
Time After: 0.07686 seconds
Time Before: 0.09024 seconds
Time After: 0.09149 seconds
End call of global.php: 0.094540119171143
Time Before: 0.10233 seconds
Time After: 0.10248 seconds
Time Before: 0.10478 seconds
Time After: 0.10620 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=105613'
WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.12433 seconds
Time After: 0.12464 seconds
Page generated in 0.123291015625 seconds with 9 queries, spending 0.0078608989715576 doing MySQL queries and 0.11543011665344 doing PHP things.
