Time Before: 0.00162 seconds
Time After: 0.00216 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00223 seconds
Time After: 0.00267 seconds
Time Before: 0.00286 seconds
Time After: 0.00298 seconds
Time Before: 0.00362 seconds
Time After: 0.00660 seconds
Time Taken: 0.00298 seconds
Time Before: 0.00302 seconds
Time After: 0.00998 seconds
Time Taken: 0.00695 seconds
Time Before: 0.01237 seconds
Time After: 0.01279 seconds
Time Before: 0.01527 seconds
Time After: 0.01653 seconds
Time Before: 0.01169 seconds
Time After: 0.01675 seconds
Time Taken: 0.00506 seconds
Time Before: 0.02202 seconds
Time After: 0.02215 seconds
Time Before: 0.02417 seconds
Time After: 0.02538 seconds
Time Before: 0.02916 seconds
Time After: 0.02932 seconds
Time Before: 0.03149 seconds
Time After: 0.03296 seconds
UPDATE session SET lastactivity = 1773382353, location = '/forums/private.php?do=newpm&explain=1&u=105623', badlocation = 1 WHERE sessionhash = 'e0f0ca8e3048a6e309b58c7aba652665'
Time Before: 0.04590 seconds
Time After: 0.04622 seconds
