Time Before: 0.00185 seconds
Time After: 0.00246 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00256 seconds
Time After: 0.00310 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00329 seconds
Time After: 0.00343 seconds
Time Before: 0.00412 seconds
Time After: 0.00639 seconds
Time Taken: 0.00227 seconds
Time Before: 0.00347 seconds
Time After: 0.00978 seconds
Time Taken: 0.00631 seconds
Time Before: 0.01221 seconds
Time After: 0.01260 seconds
Time Before: 0.01521 seconds
Time After: 0.01646 seconds
Time Before: 0.01142 seconds
Time After: 0.01674 seconds
Time Taken: 0.00531 seconds
Time Before: 0.02448 seconds
Time After: 0.02464 seconds
Time Before: 0.02709 seconds
Time After: 0.02837 seconds
End call of global.php: 0.030043840408325
Time Before: 0.03135 seconds
Time After: 0.03150 seconds
Time Before: 0.03352 seconds
Time After: 0.03502 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1777188639, location = '/forums/private.php?do=newpm&explain=1&u=105625', badlocation = 1
WHERE sessionhash = 'e9b85940693e8ec450606894f10508c2'
Time Before: 0.04782 seconds
Time After: 0.04814 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
Page generated in 0.046884059906006 seconds with 9 queries, spending 0.0080058574676514 doing MySQL queries and 0.038878202438354 doing PHP things.
