Time Before: 0.00462 seconds
Time After: 0.00536 seconds
Time Taken: 0.00074 seconds
Time Before: 0.00543 seconds
Time After: 0.00587 seconds
Time Before: 0.00607 seconds
Time After: 0.00622 seconds
Time Before: 0.00707 seconds
Time After: 0.01006 seconds
Time Taken: 0.00299 seconds
Time Before: 0.00627 seconds
Time After: 0.01583 seconds
Time Taken: 0.00956 seconds
Time Before: 0.01989 seconds
Time After: 0.02034 seconds
Time Before: 0.02290 seconds
Time After: 0.02417 seconds
Time Before: 0.01900 seconds
Time After: 0.02444 seconds
Time Taken: 0.00544 seconds
Time Before: 0.03629 seconds
Time After: 0.03642 seconds
Time Before: 0.04171 seconds
Time After: 0.04296 seconds
End call of global.php: 0.044620037078857
Time Before: 0.04730 seconds
Time After: 0.04745 seconds
Time Before: 0.05008 seconds
Time After: 0.05307 seconds
SET lastactivity = 1789075773, location = '/forums/private.php?do=newpm&explain=1&u=105637'
Time Before: 0.06732 seconds
Time After: 0.06763 seconds
Page generated in 0.066200017929077 seconds with 9 queries, spending 0.010152816772461 doing MySQL queries and 0.056047201156616 doing PHP things.
