Time Before: 0.02050 seconds
Time After: 0.02513 seconds
Time Taken: 0.00463 seconds
Time Before: 0.02520 seconds
Time After: 0.02576 seconds
Time Taken: 0.00055 seconds
Time Before: 0.02607 seconds
Time After: 0.02624 seconds
Time Before: 0.02707 seconds
Time After: 0.02999 seconds
Time Taken: 0.00293 seconds
Time Before: 0.02631 seconds
Time After: 0.03446 seconds
Time Taken: 0.00815 seconds
Time Before: 0.04341 seconds
Time After: 0.04363 seconds
Time Before: 0.04628 seconds
Time After: 0.04747 seconds
Time Before: 0.04275 seconds
Time After: 0.04765 seconds
Time Taken: 0.00490 seconds
Time Before: 0.09187 seconds
Time After: 0.09201 seconds
Time Before: 0.11326 seconds
Time After: 0.11465 seconds
Time Taken: 0.00139 seconds
Time Before: 0.12709 seconds
Time After: 0.12725 seconds
Time Before: 0.12998 seconds
Time After: 0.13139 seconds
UPDATE session SET lastactivity = 1776630653, location = '/forums/private.php?do=newpm&explain=1&u=105640', badlocation = 1 WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.14905 seconds
Time After: 0.14930 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
