Time Before: 0.01573 seconds
Time After: 0.02038 seconds
Time Taken: 0.00465 seconds
Time Before: 0.02049 seconds
Time After: 0.02096 seconds
Time Before: 0.02118 seconds
Time After: 0.02133 seconds
Time Before: 0.02209 seconds
Time After: 0.02482 seconds
Time Taken: 0.00273 seconds
Time Before: 0.02139 seconds
Time After: 0.02885 seconds
Time Taken: 0.00746 seconds
Time Before: 0.03338 seconds
Time After: 0.03358 seconds
Time Before: 0.03635 seconds
Time After: 0.03753 seconds
Time Taken: 0.00117 seconds
Time Before: 0.03272 seconds
Time After: 0.03772 seconds
Time Taken: 0.00500 seconds
Time Before: 0.06621 seconds
Time After: 0.06636 seconds
Time Before: 0.07691 seconds
Time After: 0.07812 seconds
End call of global.php: 0.079912900924683
Time Before: 0.08434 seconds
Time After: 0.08449 seconds
Time Before: 0.08662 seconds
Time After: 0.08805 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=105666', badlocation = 1
Time Before: 0.10600 seconds
Time After: 0.10632 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
Page generated in 0.10502886772156 seconds with 9 queries, spending 0.0079896450042725 doing MySQL queries and 0.097039222717285 doing PHP things.
