Time Before: 0.00935 seconds
Time After: 0.01184 seconds
Time Taken: 0.00249 seconds
Time Before: 0.01196 seconds
Time After: 0.01302 seconds
Time Taken: 0.00106 seconds
Time Before: 0.01333 seconds
Time After: 0.01348 seconds
Time Before: 0.01440 seconds
Time After: 0.01688 seconds
Time Taken: 0.00248 seconds
Time Before: 0.01355 seconds
Time After: 0.02148 seconds
Time Taken: 0.00793 seconds
Time Before: 0.02562 seconds
Time After: 0.02606 seconds
Time Before: 0.02880 seconds
Time After: 0.03050 seconds
Time Taken: 0.00170 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02472 seconds
Time After: 0.03087 seconds
Time Taken: 0.00615 seconds
Memory After: 2,261.703 KB
Time Before: 0.04553 seconds
Time After: 0.04570 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.05420 seconds
Time After: 0.05546 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.057208061218262
Time Before: 0.06014 seconds
Time After: 0.06028 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.06228 seconds
Time After: 0.06376 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=105680'
Time Before: 0.07864 seconds
Time After: 0.07893 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.077593088150024 seconds with 9 queries, spending 0.0091712474822998 doing MySQL queries and 0.068421840667725 doing PHP things.
