Time Before: 0.02757 seconds
Time After: 0.03467 seconds
Time Taken: 0.00711 seconds
Time Before: 0.03478 seconds
Time After: 0.03534 seconds
Time Taken: 0.00056 seconds
Time Before: 0.03563 seconds
Time After: 0.03580 seconds
Time Before: 0.03681 seconds
Time After: 0.04042 seconds
Time Taken: 0.00361 seconds
Time Before: 0.03587 seconds
Time After: 0.04460 seconds
Time Taken: 0.00873 seconds
Time Before: 0.05267 seconds
Time After: 0.05323 seconds
Time Before: 0.05766 seconds
Time After: 0.05998 seconds
Time Taken: 0.00232 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.05189 seconds
Time After: 0.06021 seconds
Time Taken: 0.00833 seconds
Memory After: 2,261.820 KB
Time Before: 0.11748 seconds
Time After: 0.11769 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.14102 seconds
Time After: 0.14232 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.15676 seconds
Time After: 0.15696 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.16009 seconds
Time After: 0.16150 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788949426, location = '/forums/private.php?do=newpm&explain=1&u=105688' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.18372 seconds
Time After: 0.18399 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
