Time Before: 0.01481 seconds
Time After: 0.02016 seconds
Time Taken: 0.00535 seconds
Time Before: 0.02027 seconds
Time After: 0.02069 seconds
Time Before: 0.02101 seconds
Time After: 0.02119 seconds
Time Before: 0.02208 seconds
Time After: 0.02448 seconds
Time Taken: 0.00240 seconds
Time Before: 0.02127 seconds
Time After: 0.02996 seconds
Time Taken: 0.00869 seconds
Time Before: 0.03507 seconds
Time After: 0.03530 seconds
Time Before: 0.03679 seconds
Time After: 0.03799 seconds
Time Before: 0.03427 seconds
Time After: 0.03821 seconds
Time Taken: 0.00394 seconds
Time Before: 0.06189 seconds
Time After: 0.06204 seconds
Time Before: 1.39809 seconds
Time After: 1.40103 seconds
Time Taken: 0.00294 seconds
Time Before: 1.40997 seconds
Time After: 1.41016 seconds
Time Before: 1.41293 seconds
Time After: 1.41464 seconds
Time Taken: 0.00171 seconds
UPDATE session SET lastactivity = 1776807040, location = '/forums/private.php?do=newpm&explain=1&u=105694' WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 1.43146 seconds
Time After: 1.43174 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
