Time Before: 0.00179 seconds
Time After: 0.00230 seconds
Time Before: 0.00237 seconds
Time After: 0.00278 seconds
Time Before: 0.00299 seconds
Time After: 0.00313 seconds
Time Before: 0.00378 seconds
Time After: 0.00602 seconds
Time Taken: 0.00223 seconds
Time Before: 0.00318 seconds
Time After: 0.00946 seconds
Time Taken: 0.00629 seconds
Time Before: 0.01139 seconds
Time After: 0.01176 seconds
Time Before: 0.01473 seconds
Time After: 0.01595 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01067 seconds
Time After: 0.01624 seconds
Time Taken: 0.00557 seconds
Memory After: 2,261.703 KB
Time Before: 0.02298 seconds
Time After: 0.02313 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02554 seconds
Time After: 0.02676 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.029077053070068
Time Before: 0.03052 seconds
Time After: 0.03072 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03361 seconds
Time After: 0.03511 seconds
Time Taken: 0.00150 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=105700', badlocation = 1
Time Before: 0.04885 seconds
Time After: 0.04917 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.047914028167725 seconds with 9 queries, spending 0.0077605247497559 doing MySQL queries and 0.040153503417969 doing PHP things.
