Time Before: 0.01105 seconds
Time After: 0.01433 seconds
Time Taken: 0.00328 seconds
Time Before: 0.01443 seconds
Time After: 0.01503 seconds
Time Taken: 0.00060 seconds
Time Before: 0.01536 seconds
Time After: 0.01548 seconds
Time Before: 0.01627 seconds
Time After: 0.01892 seconds
Time Taken: 0.00265 seconds
Time Before: 0.01557 seconds
Time After: 0.02300 seconds
Time Taken: 0.00743 seconds
Time Before: 0.02786 seconds
Time After: 0.02828 seconds
Time Before: 0.03095 seconds
Time After: 0.03220 seconds
Time Before: 0.02715 seconds
Time After: 0.03243 seconds
Time Taken: 0.00528 seconds
Time Before: 0.05433 seconds
Time After: 0.05450 seconds
Time Before: 0.06494 seconds
Time After: 0.06622 seconds
Time Before: 0.07430 seconds
Time After: 0.07459 seconds
Time Before: 0.07740 seconds
Time After: 0.07888 seconds
UPDATE session SET lastactivity = 1783172403, location = '/forums/private.php?do=newpm&explain=1&u=105707' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.09925 seconds
Time After: 0.09960 seconds
Memory Before: 4,289.063 KB
Memory After: 4,289.289 KB
