Time Before: 0.00586 seconds
Time After: 0.00763 seconds
Time Taken: 0.00177 seconds
Time Before: 0.00770 seconds
Time After: 0.00811 seconds
Time Before: 0.00831 seconds
Time After: 0.00844 seconds
Time Before: 0.00909 seconds
Time After: 0.01185 seconds
Time Taken: 0.00276 seconds
Time Before: 0.00849 seconds
Time After: 0.01528 seconds
Time Taken: 0.00678 seconds
Time Before: 0.01770 seconds
Time After: 0.01799 seconds
Time Before: 0.02027 seconds
Time After: 0.02159 seconds
Time Taken: 0.00132 seconds
Time Before: 0.01711 seconds
Time After: 0.02177 seconds
Time Taken: 0.00466 seconds
Time Before: 0.03561 seconds
Time After: 0.03578 seconds
Time Before: 0.04198 seconds
Time After: 0.04328 seconds
Time Before: 0.04835 seconds
Time After: 0.04849 seconds
Time Before: 0.05050 seconds
Time After: 0.05194 seconds
UPDATE session SET lastactivity = 1784733398, location = '/forums/private.php?do=newpm&explain=1&u=105732' WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.06533 seconds
Time After: 0.06564 seconds
