Time Before: 0.02562 seconds
Time After: 0.03533 seconds
Time Taken: 0.00971 seconds
Time Before: 0.03545 seconds
Time After: 0.03592 seconds
Time Before: 0.03618 seconds
Time After: 0.03635 seconds
Time Before: 0.03716 seconds
Time After: 0.04083 seconds
Time Taken: 0.00368 seconds
Time Before: 0.03643 seconds
Time After: 0.04663 seconds
Time Taken: 0.01020 seconds
Time Before: 0.05755 seconds
Time After: 0.05776 seconds
Time Before: 0.06221 seconds
Time After: 0.06489 seconds
Time Taken: 0.00268 seconds
Time Before: 0.05683 seconds
Time After: 0.06514 seconds
Time Taken: 0.00831 seconds
Time Before: 0.09669 seconds
Time After: 0.09685 seconds
Time Before: 0.66710 seconds
Time After: 0.66902 seconds
Time Taken: 0.00192 seconds
Time Before: 0.67867 seconds
Time After: 0.67883 seconds
Time Before: 0.68204 seconds
Time After: 0.68361 seconds
Time Taken: 0.00157 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=105758', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.70040 seconds
Time After: 0.70074 seconds
