Time Before: 0.01827 seconds
Time After: 0.02399 seconds
Time Taken: 0.00572 seconds
Time Before: 0.02410 seconds
Time After: 0.02454 seconds
Time Before: 0.02485 seconds
Time After: 0.02499 seconds
Time Before: 0.02592 seconds
Time After: 0.02807 seconds
Time Taken: 0.00215 seconds
Time Before: 0.02505 seconds
Time After: 0.03225 seconds
Time Taken: 0.00719 seconds
Time Before: 0.04037 seconds
Time After: 0.04091 seconds
Time Taken: 0.00054 seconds
Time Before: 0.04397 seconds
Time After: 0.04546 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03955 seconds
Time After: 0.04568 seconds
Time Taken: 0.00613 seconds
Memory After: 2,261.820 KB
Time Before: 0.07068 seconds
Time After: 0.07083 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 1.44715 seconds
Time After: 1.44890 seconds
Time Taken: 0.00175 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 1.46072 seconds
Time After: 1.46087 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 1.46376 seconds
Time After: 1.46520 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788962644, location = '/forums/private.php?do=newpm&explain=1&u=105803' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 1.48563 seconds
Time After: 1.48590 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
