Time Before: 0.00159 seconds
Time After: 0.00204 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.00211 seconds
Time After: 0.00255 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.00276 seconds
Time After: 0.00292 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.00357 seconds
Time After: 0.00608 seconds
Time Taken: 0.00250 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.00296 seconds
Time After: 0.00949 seconds
Time Taken: 0.00653 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.195 KB
Time Before: 0.01145 seconds
Time After: 0.01195 seconds
Memory Before: 2,758.008 KB
Memory After: 2,758.625 KB
Time Before: 0.01438 seconds
Time After: 0.01554 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,770.180 KB
Memory After: 2,770.039 KB
Time Before: 0.01073 seconds
Time After: 0.01574 seconds
Time Taken: 0.00500 seconds
Memory Before: 2,750.156 KB
Memory After: 2,883.398 KB
Memory Used: 133.242 KB
Time Before: 0.02064 seconds
Time After: 0.02079 seconds
Memory Before: 3,436.508 KB
Memory After: 3,437.023 KB
Time Before: 0.02263 seconds
Time After: 0.02390 seconds
Memory Before: 3,524.281 KB
Memory After: 3,524.875 KB
Time Before: 0.02694 seconds
Time After: 0.02709 seconds
Memory Before: 4,162.195 KB
Memory After: 4,162.625 KB
Time Before: 0.02917 seconds
Time After: 0.03059 seconds
Memory Before: 4,443.734 KB
Memory After: 4,445.422 KB
UPDATE session SET lastactivity = 1788957859, location = '/forums/private.php?do=newpm&explain=1&u=105809', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04289 seconds
Time After: 0.04320 seconds
Memory Before: 4,922.320 KB
Memory After: 4,922.531 KB
