Time Before: 0.01861 seconds
Time After: 0.02292 seconds
Time Taken: 0.00431 seconds
Time Before: 0.02299 seconds
Time After: 0.02347 seconds
Time Before: 0.02371 seconds
Time After: 0.02382 seconds
Time Before: 0.02450 seconds
Time After: 0.02681 seconds
Time Taken: 0.00231 seconds
Time Before: 0.02387 seconds
Time After: 0.03072 seconds
Time Taken: 0.00685 seconds
Time Before: 0.03717 seconds
Time After: 0.03761 seconds
Time Before: 0.03904 seconds
Time After: 0.04029 seconds
Time Before: 0.03643 seconds
Time After: 0.04051 seconds
Time Taken: 0.00408 seconds
Time Before: 0.07417 seconds
Time After: 0.07468 seconds
Time Before: 0.09027 seconds
Time After: 0.09162 seconds
Time Taken: 0.00134 seconds
Time Before: 0.10198 seconds
Time After: 0.10236 seconds
Time Before: 0.10449 seconds
Time After: 0.10591 seconds
UPDATE session SET lastactivity = 1780637331, location = '/forums/private.php?do=newpm&explain=1&u=105816', badlocation = 1 WHERE sessionhash = 'f0a2de90bc45baf36aaf71071f1bfe42'
Time Before: 0.12179 seconds
Time After: 0.12211 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
