Time Before: 0.01653 seconds
Time After: 0.02132 seconds
Time Taken: 0.00480 seconds
Time Before: 0.02142 seconds
Time After: 0.02188 seconds
Time Before: 0.02212 seconds
Time After: 0.02225 seconds
Time Before: 0.02310 seconds
Time After: 0.02563 seconds
Time Taken: 0.00253 seconds
Time Before: 0.02233 seconds
Time After: 0.03009 seconds
Time Taken: 0.00776 seconds
Time Before: 0.03573 seconds
Time After: 0.03598 seconds
Time Before: 0.03727 seconds
Time After: 0.03852 seconds
Time Before: 0.03512 seconds
Time After: 0.03877 seconds
Time Taken: 0.00365 seconds
Time Before: 0.06589 seconds
Time After: 0.06606 seconds
Time Before: 0.07769 seconds
Time After: 0.07899 seconds
Time Before: 0.08634 seconds
Time After: 0.08651 seconds
Time Before: 0.08966 seconds
Time After: 0.09129 seconds
Time Taken: 0.00162 seconds
UPDATE session SET lastactivity = 1784808461, location = '/forums/private.php?do=newpm&explain=1&u=105818', badlocation = 1 WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.11039 seconds
Time After: 0.11070 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
