Time Before: 0.02201 seconds
Time After: 0.02993 seconds
Time Taken: 0.00793 seconds
Time Before: 0.03004 seconds
Time After: 0.03097 seconds
Time Taken: 0.00092 seconds
Time Before: 0.03132 seconds
Time After: 0.03145 seconds
Time Before: 0.03223 seconds
Time After: 0.03420 seconds
Time Taken: 0.00197 seconds
Time Before: 0.03150 seconds
Time After: 0.03835 seconds
Time Taken: 0.00685 seconds
Time Before: 0.04864 seconds
Time After: 0.04905 seconds
Time Before: 0.05067 seconds
Time After: 0.05193 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04778 seconds
Time After: 0.05221 seconds
Time Taken: 0.00443 seconds
Memory After: 2,261.703 KB
Time Before: 0.08762 seconds
Time After: 0.08780 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.38757 seconds
Time After: 0.38882 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.40113 seconds
Time After: 0.40130 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.40426 seconds
Time After: 0.40574 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=105826', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.42574 seconds
Time After: 0.42601 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
