Time Before: 0.00146 seconds
Time After: 0.00192 seconds
Time Before: 0.00199 seconds
Time After: 0.00255 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00284 seconds
Time After: 0.00295 seconds
Time Before: 0.00373 seconds
Time After: 0.00594 seconds
Time Taken: 0.00222 seconds
Time Before: 0.00301 seconds
Time After: 0.00933 seconds
Time Taken: 0.00633 seconds
Time Before: 0.01110 seconds
Time After: 0.01128 seconds
Time Before: 0.01440 seconds
Time After: 0.01565 seconds
Time Before: 0.01050 seconds
Time After: 0.01583 seconds
Time Taken: 0.00533 seconds
Time Before: 0.02102 seconds
Time After: 0.02120 seconds
Time Before: 0.02324 seconds
Time After: 0.02448 seconds
Time Before: 0.02816 seconds
Time After: 0.02857 seconds
Time Before: 0.03119 seconds
Time After: 0.03261 seconds
UPDATE session SET lastactivity = 1789082450, location = '/forums/private.php?do=newpm&explain=1&u=105831', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04501 seconds
Time After: 0.04536 seconds
