Time Before: 0.01156 seconds
Time After: 0.01568 seconds
Time Taken: 0.00413 seconds
Time Before: 0.01578 seconds
Time After: 0.01620 seconds
Time Before: 0.01645 seconds
Time After: 0.01657 seconds
Time Before: 0.01746 seconds
Time After: 0.01963 seconds
Time Taken: 0.00216 seconds
Time Before: 0.01664 seconds
Time After: 0.02473 seconds
Time Taken: 0.00809 seconds
Time Before: 0.03012 seconds
Time After: 0.03033 seconds
Time Before: 0.03443 seconds
Time After: 0.03563 seconds
Time Before: 0.02949 seconds
Time After: 0.03586 seconds
Time Taken: 0.00637 seconds
Time Before: 0.05675 seconds
Time After: 0.05690 seconds
Time Before: 0.23710 seconds
Time After: 0.23832 seconds
Time Before: 0.24827 seconds
Time After: 0.24842 seconds
Time Before: 0.25076 seconds
Time After: 0.25219 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=105832', badlocation = 1 WHERE sessionhash = '32502f71822f8bf82bf8c86767d671b1'
Time Before: 0.26729 seconds
Time After: 0.26760 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
