Time Before: 0.01795 seconds
Time After: 0.02359 seconds
Time Taken: 0.00564 seconds
Time Before: 0.02369 seconds
Time After: 0.02413 seconds
Time Before: 0.02540 seconds
Time After: 0.02554 seconds
Time Before: 0.02635 seconds
Time After: 0.02878 seconds
Time Taken: 0.00243 seconds
Time Before: 0.02562 seconds
Time After: 0.03279 seconds
Time Taken: 0.00717 seconds
Time Before: 0.04148 seconds
Time After: 0.04183 seconds
Time Before: 0.04437 seconds
Time After: 0.04558 seconds
Time Before: 0.04084 seconds
Time After: 0.04580 seconds
Time Taken: 0.00496 seconds
Time Before: 0.06862 seconds
Time After: 0.06876 seconds
Time Before: 0.08776 seconds
Time After: 0.08954 seconds
Time Taken: 0.00178 seconds
Time Before: 0.09813 seconds
Time After: 0.09827 seconds
Time Before: 0.10071 seconds
Time After: 0.10218 seconds
UPDATE session SET lastactivity = 1785338545, location = '/forums/private.php?do=newpm&explain=1&u=105883' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.12144 seconds
Time After: 0.12178 seconds
