Time Before: 0.00291 seconds
Time After: 0.00400 seconds
Time Taken: 0.00109 seconds
Time Before: 0.00408 seconds
Time After: 0.00447 seconds
Time Before: 0.00464 seconds
Time After: 0.00478 seconds
Time Before: 0.00543 seconds
Time After: 0.00756 seconds
Time Taken: 0.00213 seconds
Time Before: 0.00483 seconds
Time After: 0.01258 seconds
Time Taken: 0.00774 seconds
Time Before: 0.01534 seconds
Time After: 0.01574 seconds
Time Before: 0.01833 seconds
Time After: 0.01959 seconds
Time Before: 0.01459 seconds
Time After: 0.01986 seconds
Time Taken: 0.00527 seconds
Time Before: 0.03155 seconds
Time After: 0.03169 seconds
Time Before: 0.03520 seconds
Time After: 0.03644 seconds
Time Before: 0.04129 seconds
Time After: 0.04148 seconds
Time Before: 0.04506 seconds
Time After: 0.04723 seconds
Time Taken: 0.00217 seconds
UPDATE session SET lastactivity = 1789049229, location = '/forums/private.php?do=newpm&explain=1&u=105907', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.06348 seconds
Time After: 0.06428 seconds
Time Taken: 0.00080 seconds
