Time Before: 0.00607 seconds
Time After: 0.00904 seconds
Time Taken: 0.00297 seconds
Time Before: 0.00911 seconds
Time After: 0.00965 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00991 seconds
Time After: 0.01004 seconds
Time Before: 0.01090 seconds
Time After: 0.01524 seconds
Time Taken: 0.00435 seconds
Time Before: 0.01012 seconds
Time After: 0.02010 seconds
Time Taken: 0.00998 seconds
Time Before: 0.02429 seconds
Time After: 0.02469 seconds
Time Before: 0.02717 seconds
Time After: 0.02836 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02355 seconds
Time After: 0.02862 seconds
Time Taken: 0.00507 seconds
Memory After: 2,261.820 KB
Time Before: 0.04385 seconds
Time After: 0.04400 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.05294 seconds
Time After: 0.05420 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.056164979934692
Time Before: 0.06084 seconds
Time After: 0.06099 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.06332 seconds
Time After: 0.06475 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788887293, location = '/forums/private.php?do=newpm&explain=1&u=105925'
Time Before: 0.08192 seconds
Time After: 0.08221 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.080880880355835 seconds with 9 queries, spending 0.0098795890808105 doing MySQL queries and 0.071001291275024 doing PHP things.
