Time Before: 0.01268 seconds
Time After: 0.01784 seconds
Time Taken: 0.00516 seconds
Time Before: 0.01798 seconds
Time After: 0.01845 seconds
Time Before: 0.01869 seconds
Time After: 0.01884 seconds
Time Before: 0.01978 seconds
Time After: 0.02212 seconds
Time Taken: 0.00234 seconds
Time Before: 0.01893 seconds
Time After: 0.02635 seconds
Time Taken: 0.00742 seconds
Time Before: 0.03082 seconds
Time After: 0.03108 seconds
Time Before: 0.03370 seconds
Time After: 0.03486 seconds
Time Taken: 0.00116 seconds
Time Before: 0.03010 seconds
Time After: 0.03511 seconds
Time Taken: 0.00501 seconds
Time Before: 0.05724 seconds
Time After: 0.05740 seconds
Time Before: 0.06556 seconds
Time After: 0.06680 seconds
Time Before: 0.07320 seconds
Time After: 0.07341 seconds
Time Before: 0.07583 seconds
Time After: 0.07726 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=105931', badlocation = 1 WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.09315 seconds
Time After: 0.09344 seconds
