Time Before: 0.01858 seconds
Time After: 0.02456 seconds
Time Taken: 0.00599 seconds
Time Before: 0.02467 seconds
Time After: 0.02524 seconds
Time Taken: 0.00057 seconds
Time Before: 0.02558 seconds
Time After: 0.02576 seconds
Time Before: 0.02663 seconds
Time After: 0.03008 seconds
Time Taken: 0.00345 seconds
Time Before: 0.02583 seconds
Time After: 0.03444 seconds
Time Taken: 0.00861 seconds
Time Before: 0.04281 seconds
Time After: 0.04306 seconds
Time Before: 0.04439 seconds
Time After: 0.04564 seconds
Time Before: 0.04209 seconds
Time After: 0.04586 seconds
Time Taken: 0.00376 seconds
Time Before: 0.07703 seconds
Time After: 0.07727 seconds
Time Before: 0.09859 seconds
Time After: 0.09987 seconds
Time Before: 0.11286 seconds
Time After: 0.11307 seconds
Time Before: 0.11582 seconds
Time After: 0.11734 seconds
Time Taken: 0.00152 seconds
UPDATE session SET lastactivity = 1782864594, location = '/forums/private.php?do=newpm&explain=1&u=105933', badlocation = 1 WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.13937 seconds
Time After: 0.13966 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
