Time Before: 0.00138 seconds
Time After: 0.00198 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00205 seconds
Time After: 0.00249 seconds
Time Before: 0.00269 seconds
Time After: 0.00281 seconds
Time Before: 0.00353 seconds
Time After: 0.00645 seconds
Time Taken: 0.00291 seconds
Time Before: 0.00285 seconds
Time After: 0.01161 seconds
Time Taken: 0.00875 seconds
Time Before: 0.01384 seconds
Time After: 0.01427 seconds
Time Before: 0.01682 seconds
Time After: 0.01801 seconds
Time Before: 0.01318 seconds
Time After: 0.01826 seconds
Time Taken: 0.00508 seconds
Time Before: 0.02588 seconds
Time After: 0.02601 seconds
Time Before: 0.02845 seconds
Time After: 0.02968 seconds
End call of global.php: 0.032116174697876
Time Before: 0.03368 seconds
Time After: 0.03390 seconds
Time Before: 0.03592 seconds
Time After: 0.03736 seconds
SET lastactivity = 1768901836, location = '/forums/private.php?do=newpm&explain=1&u=105947'
WHERE sessionhash = '498d073752497ccaba409783e9267bef'
Time Before: 0.05133 seconds
Time After: 0.05161 seconds
Memory Before: 4,912.039 KB
Memory After: 4,912.266 KB
Page generated in 0.050424098968506 seconds with 9 queries, spending 0.0083987712860107 doing MySQL queries and 0.042025327682495 doing PHP things.
