Time Before: 0.00941 seconds
Time After: 0.01167 seconds
Time Taken: 0.00225 seconds
Time Before: 0.01177 seconds
Time After: 0.01225 seconds
Time Before: 0.01269 seconds
Time After: 0.01288 seconds
Time Before: 0.01377 seconds
Time After: 0.01629 seconds
Time Taken: 0.00252 seconds
Time Before: 0.01294 seconds
Time After: 0.02177 seconds
Time Taken: 0.00883 seconds
Time Before: 0.02583 seconds
Time After: 0.02626 seconds
Time Before: 0.02893 seconds
Time After: 0.03088 seconds
Time Taken: 0.00195 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02510 seconds
Time After: 0.03105 seconds
Time Taken: 0.00595 seconds
Memory After: 2,261.820 KB
Time Before: 0.04495 seconds
Time After: 0.04513 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.05092 seconds
Time After: 0.05224 seconds
Time Taken: 0.00132 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.05801 seconds
Time After: 0.05819 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.06121 seconds
Time After: 0.06378 seconds
Time Taken: 0.00258 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789065104, location = '/forums/private.php?do=newpm&explain=1&u=105949', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.07991 seconds
Time After: 0.08021 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
