Time Before: 0.00224 seconds
Time After: 0.00286 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00295 seconds
Time After: 0.00334 seconds
Time Before: 0.00353 seconds
Time After: 0.00364 seconds
Time Before: 0.00426 seconds
Time After: 0.00742 seconds
Time Taken: 0.00316 seconds
Time Before: 0.00369 seconds
Time After: 0.01090 seconds
Time Taken: 0.00721 seconds
Time Before: 0.01305 seconds
Time After: 0.01331 seconds
Time Before: 0.01471 seconds
Time After: 0.01586 seconds
Time Taken: 0.00115 seconds
Time Before: 0.01242 seconds
Time After: 0.01604 seconds
Time Taken: 0.00362 seconds
Time Before: 0.02154 seconds
Time After: 0.02165 seconds
Time Taken: 0.00010 seconds
Time Before: 0.02488 seconds
Time After: 0.02618 seconds
Time Before: 0.02965 seconds
Time After: 0.02977 seconds
Time Before: 0.03165 seconds
Time After: 0.03307 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=105955' WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.04567 seconds
Time After: 0.04592 seconds
